convert ascii to hexadecimal
They forgive my weak knowledge of labview. It needed that they helped me, to convert AsciiI into hexadecimal. I give the following example:    I have a string #01SVT<BL>+098,037 (ASCII) = 2C9 (hexadecimal). how it is that I can get this for labview?    Debtor, and I ask for excuse for my English.
(5,613 Views)
Hi Luigi,
why is 2C9 (hexadecimal) = #01SVT<BL>+098,037 (ASCII)?? But anyway, if you want to split your String to extract some parts of the String, there is a function called "split string"
. And from that splitted part you can make a conversion to a hexadecimal string by converting it into an integer and converting back to a hexa- string. All that functions you can find in the "string"-palette.
Another hint (and one of the reasons i'm so inspired by LabView) is: If you want to test the behaviour of a function or VI, simply open a new blank VI, drop the function to examine and create appropriate controls and indicators of the interesting In- and Outputs by the context menu of the connectors. Then you can type in some testdata and run the VI to see, what the function does. This is a very fast way to create a testing environment for the function.
Hope this helps,
Dave
Greets, Dave
(5,600 Views)
as Dave said use the string convertion VI of Labview, see link below:
http://forums.ni.com/ni/board/message?board.id=170&message.id=185734
ClémentG
(5,575 Views)
Hello
I want to convert a string "02 sRN LMDsacandata 03" from ASCII to HEX to communicate via TCP/IP with a device(LMS111). I've tried to split the string in 3 parts and then concatenate it, but i don't get the right convertion (02 73 52 4E 20 4C 4D 44 73 63 61 6E 64 61 74 61 03). Can anybody help me with this problem?
Thanks.
(4,948 Views)
Your conversion of STX to an I32 (4 bytes) is all wrong. If the control is set for hex display, you don't need to convert anything at all.
(4,941 Views)
You're overdoing it. All you need to do is to concatenate the strings. Just make sure the strings are in hex display mode.
Edit: What he said. Smiley Very Happy
(4,939 Views)
