convert boolean numbers into waveform
i am using PXI 7833R  and generate a clock using loop timer. I want to use a wave indicator to show the clock. However the output is a boolean number, I am wondering if there is a VI or something that can wave out the boolean value.
(3,995 Views)
You could use Boolean to (0,1) from the boolean palette. It will give you a one for true and a zero for false.
(3,990 Views)
how to wave the 0,1 out ?
like a normal digital wave form
(3,989 Views)
I assume that you are talking about the need to display your data in the form of a digital waveform.  In LabVIEW you can plot digital waveforms on a Digital Waveform Graph much like other waveforms.  Remember, with a graph, you are not plotting updating points, so if you would like to keep a history of previous values you will need to continually append your new data points to the existing ones and redraw the graph.  I recommend starting out by examining the examples for Digital Waveforms in the NI Example Finder (Help->Find Examples->Fundamentals->Charts and Graphs).
Thanks for posting, and please let us know if you have any other questions, or you would like to see some more examples.
Travis M
LabVIEW R&D
(3,967 Views)
