convert *.dat to image
i have converted image into *.dat file in matlab , but now i want to convert  *.dat file into image format in labview ,
how can i do it.
thanks and regards
Message 1 of 13
(5,934 Views)
Why not store the image as jpeg instead of the dat file?
Santhosh
Soliton Technologies
Message 2 of 13
(5,917 Views)
What version of LabVIEW are you using?
Does it support MATLAB script?
George Zou
Message 3 of 13
(5,903 Views)
A *.dat file can be anything. Unlike e.g. *.png it is not reserved for any specific data structure.
So have a look at your Matlab code to see how the data is saved, then reverse engineer it in LabVIEW. If it is binary, you need to know the # of rows and # of columns, the datatype (# of bytes per pixel, B&W, RGB? RGBA? Palleted?) and the byte order for any multibyte value. I am sure it is all in there somewhere....
Message 4 of 13
(5,892 Views)
the application is such a way that i have to convert to *.dat then into image
regards
Message 5 of 13
(5,829 Views)
how can i do it.
thanks and regards
You do the same procedure as you did in Matlab, but in reverse. How's the image saved? Pure data? Any header? 24 bit RGB values?
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 13
(5,812 Views)
If you use IMAQ Vision functions you would basically import the numeric data in whatever binary format you write it in Matlab and then use the IMAQ Array To Image functions.
If you want to use the LabVIEW Pixmap format instead you need to do the same import and then try using one of the Draw Unflattened Pixmap instances.
Rolf Kalbermatter  My Blog
Message 7 of 13
(5,805 Views)
I'am able to convert *.dat to *.png  image, but i'am getting two images in earth.png
regards
Message 8 of 13
(5,794 Views)
Hi V.,
Then your conversion is wrong!
(Are you sure your "dat" data is organized in a 900×900 scheme?)
Btw. why don't you cleanup the code before posting such images?
Message 9 of 13
(5,791 Views)
the gray scale image is 810000 bytes i'am using reshape array to to convert it into 2d array, how can i get single image instead of two
Regards
Message 10 of 13
(5,786 Views)
