convert data in the text file to table in DBL
awesome.
1)whats the thing behind the small trick?
2) Is the table format same with the 2D array of DBL cause i will have to use it later. I need the data in DBL of 2D array.
3)also explain abt my mistake too
thanks mike. saviour of the day .
Message 11 of 30
(1,365 Views)
Hi sean,
here's the hard way:
Hmm, Mike beats me... And his solution is more elegant, but: mine is the "hard way"Smiley Wink
Sean:
The trick is to know the correct separator between your data. In your case it's not the (usual) tab, but a double space!
Message Edited by GerdW on 05-21-2008 09:23 AM
Message 12 of 30
(1,365 Views)
thks for the reply too.
U're the best. But mike is simple and elegant.
GerdW could u explain urs too cos I had diffculties understanding.. i just a newbie though i had completed all the neccessary studies
Message 13 of 30
(1,356 Views)
Hi Sean
the two functions are "Search and replace chars" (in the while loop) and "spreadsheet string to array". The rest should be clear from the comments...
I was misguided by the fact that there are sometimes 2, sometimes 3 spaces depending on sign of following number. That's why I took the long way. Use Mike's example, it's much more readable...
Our both solutions will show a first column with zeros, you may want to strip it...
Message 14 of 30
(1,350 Views)
i dunno why there is /s and %g purpose?
can u explain gerald ?
Message 15 of 30
(1,345 Views)
Hi Sean,
my name is not "gerald"Smiley Sad
"/s" is a space display as "/ code" (Mike is using them too!), "%g" is the format code needed by SpreadsheetStringToArray and means "scientific format". You find all those format codes in the LabView help, it's a huge page full of themSmiley Wink
Message Edited by GerdW on 05-21-2008 10:08 AM
Message 16 of 30
(1,338 Views)
This is not the first time Smiley Surprised names are misunderstood Smiley Wink ....
Mathan
Message Edited by mathan on 05-21-2008 03:33 AM
Message 17 of 30
(1,330 Views)
Mathan
Message 18 of 30
(1,330 Views)
Smiley Surprised
my bad
i got a problem now. though i used mike.vi at some part of my table. I found out to have 0.00 data. because my table contain some DBL values.
Message 19 of 30
(1,324 Views)
Hi Mathan,
misspelling/-pronouncing are different than just wildly guessing the nameSmiley Wink
Hi Sean,
I found out to have 0.00 data. because my table contain some DBL values" ??? Where's the connection here? Zero because of DBL???
Message 20 of 30
(1,317 Views)
