convert data to grayscale image
I'm working with Labview 7.0 and Imaq Vision.
I would like to display a picture from an array containing 8 bits data. I have created a dll that fills my array, and now I'd like to convert it in picture.
My problem is that I would like to obtain a grayscale picture, and I don't manage to do it.
I have managed to display a "blue" picture (using 32 bits data). Using 8 bits data, the picture is multicoloured.
Could you help me in doing this because I have no idea of how doing it.
Enclosed are the 2 (indepedent) VIs I have already made (using 32 or 8 bits data) with the dll (I'm using a dll because I'll need to diplay other pictures coming from hardware later).
Thank you to help me if you have an idea,
Delphine
Message 1 of 9
(4,153 Views)
Hello Delphine,
without looking at your vi's:
In 32bit-mode you got a blue picture. That's because of RGB-interpretion of your data. You supplied only the lowest 8 bit, this gives you the blue color. To get "gray" you have to supply R, G and B. All you have to do is to "multiply" your 8bit to 24bit: join 3 U8 values to a U32 for each pixel.
In 8bit-mode you got a multicolored picture. That's probably because you didn't supply a colortable. If you would supply a colortable with all gray values your picture should be fine.
Message 2 of 9
(4,140 Views)
You said that you are using Imaq Vision, but you keep using the basic LabVIEW picture display, which is an awfull tool. Complicated and terribly slow. Things would have been much simpler with the Imaq display tools, where you can easily define/choose the color palette to be used. I am not sure either that a ddl would have been required.
CC
Chilly Charly    (aka CC)
Message 3 of 9
(4,136 Views)
Thanks for your answer.
I'm using a dll because when this part will work, I will add other functions (to acquire data from hardware) for which I need a dll. So I've directly start using a ddl.
Concerning Imaq Vision, I tried to use it in the VI but I didn't manage. Could you help me doing this?
Delphine
Message 4 of 9
(4,133 Views)
Try that...
CC
Message 5 of 9
(4,129 Views)
Thanks for your response but I only have Labview 7.0.
Could you send me the same file in this version please? I will help me a lot.
Thank you,
Delphine
Message 6 of 9
(4,125 Views)
I'm trying to do the two solutions you spoke about.
Concerning the color table, could you explain me how to create a grayscale one? I tried to do it but I didn't manage.
Delphine
Message 7 of 9
(4,121 Views)
Not sure that the subs have been saved properly, but here is a 7.0 version
CC
Message 8 of 9
(4,121 Views)
It works!!!
Thank you a lot for your fast response!
Delphine
Message 9 of 9
(4,116 Views)
