convert decimal into integer
Hello i think that's a simple question. I've to convert a decimal number (such as 0,1 ) into an integer number such as 0.
What should i do? i tried with functions >> numeric >> conversions >> to long integers but i saw  it has only integers as input.
(11,764 Views)
Not 100 percent sure what you wanted, so I've provided 3 alternatives.
  1. Mathematically rounds the number to the nearest whole value (integer)
  2. Divides the number by 1 (can be any constant, but for your case, 1 is used) and returns the quotient and remainder.  The quotient is the number as if it was rounded down to the nearest whole value (integer)
  3. Blindly converts your single precision (I assume this is your data type) to a long integer.  This will also get rid of the decimal place.
I hope this helps.
  1.
P.S.  Examples 1 & 2 use DBL precision values - these are interchangeable with SGL precision values, assuming you only need 1dp precision.
Message Edited by James Mamakos on 05-11-2009 10:53 AM
Never say "Oops." Always say "Ah, interesting!"
(11,755 Views)
One addition to method 1 James posted:
Round towards nearest integer has one "exception" common to most programming languages:
If the value of the input is midway between two integers (for example, 1.5 or 2.5), the function returns the nearest even integer (2).
hope this helps,
Norbert
Norbert
Expert: Geometry
(11,735 Views)
...Wow - you serious about this?  I've absolutely never heard of that before - I'll admit I'm not that experienced with programming languages though.  Why does it do this - isn't this functionality rather illogical?  It certainly strikes me as odd, but then i don't know exactly how the computer works it out.
Could someone shed some light on this for me please.
(11,694 Views)
Here is an explanation why.
Chris M
(11,688 Views)
