convert digital waveform to number
Hi, Is there any way of converting an 8 bit serial data frame shown in a digital waveform graph into a number.
For example, the screen shot attached, with the right hand side being the MSB we have an eight bit serial data frame of 1010 1010.
I need to convert this into a number, which would be 170, but im not sure how?
Rhys
(4,879 Views)
you can use the following VIs for the conversion from digital waveform to number :
Digital Waveform to Boolean Array
Boolean Array to Number
I attached a simple example of an conversion.
  Michael
__________________________________
Certified LabVIEW Associate Developer
(4,866 Views)
