convert hex to float
I have to convert a bit Hex string into a float. I built a vi from the following C code, but it only works on positive numbers. Any suggestions?
sample16 = (short) ((MSB << 😎 | LSB);
sample = (float)sample16/32768.0;
sample*=10.0;
Message 1 of 17
(14,741 Views)
You have a ready function in LabVIEW to do that.
Look at attached pic to find it
Message 2 of 17
(14,719 Views)
Bytes are not "negative" or "positive". Do you have some more information on your conversion? Where is the sign bit?
I also assume that your MSB and LSB are originally U8. If it is just a 2byte string, feed it directly into the typecast function.
Maybe something along the lines of the attached modification will do the trick. If not, provide some sample inputs and the expected result.
Message 3 of 17
(14,713 Views)
Your vi works. Thank you
Message 4 of 17
(14,674 Views)
Dear
I am trying to convert 4 bit Hex string to floating number. Dut it does not work.
Please help.
Message 5 of 17
(11,693 Views)
Do you have a set definition of how the float is constructed?
Message 6 of 17
(11,677 Views)
Thanks Crossrulz
How to set definitions?
Hong
Message 7 of 17
(11,651 Views)
He is asking you for documentation of the format.
You strings don't conform to the IEEE 754 definition of SGL (big or little endian).
What device is generating the hex string? Do you have a manual?
Message 8 of 17
(11,646 Views)
Hi
Message 9 of 17
(11,621 Views)
Hong.Zhang@agresearch.co. wrote:
Hi @altenbach
You are not giving us any useful information.  Look up the manual of your device.  Somewhere in there should be a definition of how the numbers are built up.
Message 10 of 17
(11,603 Views)
