convert scientific string to number ?????
Could anybody tell me how I can convert a scientific string to a number ( for ex : String 7.4E-1 to 0.74 )  ?
Any help would be great !
David
Message 1 of 9
(8,347 Views)
Try this. 7.0 format. This vi is located in the All functions, String, String/number conversion on the block diagram.
Message 2 of 9
(8,342 Views)
Hi Unclebump,
Thanks for ur answer, it works fine.
cheers,
David
Message 3 of 9
(8,317 Views)
Hi
I have the same problem here, but this example does not work.
The number I try to convert ifor example is 2.78242e-03, and the answer it gives me is 2
I tried to change the precision of the indicator to the 10th digid, and tried different format modes but it does not work.
Can somebody help??
I have another issue of the same kind. I am trying to convert a fractional number to string, but it does not work.
For example I input a DBL value 2, divide it by 1000. The result shown is 0,002. Then I try to convert this to a string and the answer is " 0, ".  What I need to get as a result when I convert it to string is "0.002"
I think I have some problems with those "," and "." dividing the fractions but I cannot figure it out. I also tried to change my windows setting to have a default value "." which is separating them but it does not work out.
I am using MathLab 8.5
Please help.
Thank you for your responses.
Message 4 of 9
(8,157 Views)
Hi andreevz,
if i use the before attached example and insert you example number, it works fine for me. I work with a point as decimal seperator.
Mike
Message 5 of 9
(8,154 Views)
Sorry for troubling guys.
A good old fashioned restart fixed the problem fine Smiley Happy
Message 6 of 9
(8,149 Views)
Hi andre,
you can override system settings using special format codes in string conversions!
To convert a string to number like your example "2.78242e-03" you should use "%.;%f" as format string for "scan from string".
The same format string
"%.;%f" will give the desired result when using "Format into string" and a value of 0,002...
When changing system settings you have to restart LabView, not the whole (Windows) system...
Message Edited by GerdW on 04-02-2008 12:02 PM
Message 7 of 9
(8,146 Views)
Hai andreevz,
I tried the same with the given example. Its perfectly working without any problem for your first query. The thing is if u give a comma "," then it will just return the numbers before the decimal point. Here in this case it will give 2. If u give a dot "." then it will return the full value. That is result will be 0.00278242
Next, how u convert that value to a string? could u post ur code? so we will work it out easily.
Thanks and Regards,
Mathan
Message 8 of 9
(8,142 Views)
Thanks for all the responses people.
This forum is really great.
I already fixed the problem. I believe it was a problem with my regional settings, and when I change them and restarted LabView everything came in order. I am using the simplest functions you can find in LabView, such as convert string to fract/exp number, and convert fract number to string.
Thanks again. Later I will have more questions as I am building my first program by myself and up to now it is working almost fine 😉
Message 9 of 9
(8,139 Views)
