convert separated signals back to their correct scales
Hi, I'm working with sound signals and I combined three signals using TDM. After that I separated the signals back to their original forms but the time scale was different. Is there a function I can use to to convert the separated signals back to their correct scales ?
(930 Views)
Hi Zyad,
The question is: HOW did you combine those 3 signals?
Using the answer to this question you can (maybe) implement a way to convert "back" correctly…
(902 Views)
