convert sequence files from TS2010 to TS3.1
I have invested a lot of time to develop sequences in TS2010. Now because of our platform constrains I need the same sequences in TS 3.1. Is it somehow possible to convert the sequence files in a previous version of TS ?
regards
Mitulatbati
(2,253 Views)
Accepted by topic author mitulatbati
Mitulatbati,
you should post that question on the TS forums.
Nevertheless, you have to select "Save as" in the File menu-item. In the following dialog, you can select your TS version in the "files of type" dropdown.
Please note that if you used anything, which was introduced in TS between 3.1 and 2010, the sequence will be most probable "downconverted" without any error message. But it will not work (e.g. if you used API calls in Expressions).
thanks,
Norbert
Norbert
Expert: Geometry
(2,244 Views)
