convert sine wave to digital output
I'm using pci-6251 and Labview 8.
I have an input analog sine wave which I want to convert to an output  TTL pulse (with the same frequency). I also want to be able to control the width of the TTL pulse.
Can anyone give me some advise?
Thank you,
Shafran
(4,106 Views)
Shafran,
This KB should be a great starting point for your application. You can change the width of the pulse by changing the duty cycle.
Can I Create a Digital Pulse Train That is Synchronized with My Analog Input Signal?
http://digital.ni.com/public.nsf/allkb/67CCAAF13C8617FC86256E01006C3D69?OpenDocument
Chris Delvizis
(4,077 Views)
