convert string input from teststand to hex in labview
I am using TestStand to develop my automated test by calling the labview modules that I have created. Now I am wondering if I pass a string containing hex values to the labview module, how can I convert that into the hex string to be sent to my device?
For example:
In TestStand I create a string variable with value of "00A9 8AC7 0153 158E" and this will be fed to one of the inputs for a labview module. This module will concatenate this hex values with other pre-defined values and bundle as a command to be sent through serial to my device. How can I convert the values received from TestStand into hex representation? Meaning from "00A9 8AC7 0153 158E" (normal string) to 00A9 8AC7 0153 158E (hex format).
Thanks.
Koh
(4,237 Views)
Hexadecimal String to Number or Scan from String.
You will probably need to do this in a loop.
(4,231 Views)
Does it mean that I need to loop the string 2 extract the blocks, use "string to byte array" to convert to number, then use "number to hex string"?
Example:
Get 00A9, convert to byte, convert to hex. Then repeat for the next block.
(4,222 Views)
Below is the example to convert hex string to normal string. How should I do the reverse of this?
hex_string_to_normal_string
(4,211 Views)
it's fine now. I have succeed in converting it back. I have attached the sample. Please do provide feedback if it can be improved further.
(4,194 Views)
You should use the Quotient & Remainder instead of the divide.  That will keep it all as an integer.  I also made up an alternative.  Hard to say which one will be more efficient without doing some benchmarks.
(4,168 Views)
