convert string into a 1d array of strings
This is the output I have:
I want to take that string, and convert it to a 1d array of strings, so I can access each line, with index array.
I tried this:
But the output is a double, and I need it to be a  string.
How can I fix this?
I will leave my code, maybe someone can take a look at it.
thanks.
Message 1 of 34
(14,622 Views)
In the "Spreasheet string to array", wire a empty 1D array of string diagram constant to the type input on the lower left and use a %s format. The output will be a 1D array of strings.
Your code looks extremely convoluted. Can you create an indicator after the sytem exec, then run your Vi until intcontains data. Now stop the VI and right-click that indciator and "create constant". Save under a new name and attach it once more. Now we have typical data to play with.
Message 2 of 34
(14,614 Views)
Can I convert this string into a 2d array after the ":"?
Message 3 of 34
(14,599 Views)
Yes, of course. However, you need to explain what you atually mean by all that. Where is a "."?
We are not clairvoyant! Why don't you do what I suggested above first? Then tell us what kind of output you expect.
Message 4 of 34
(14,592 Views)
I want to change column after ":" in the string.
Message 5 of 34
(14,581 Views)
I still don't quite understand what you mean. You can use "." as column delimiter and newline will be autimatically the row delimiter once you wire a 2D array of string.
It would really make things much more clear if you would actually do what I requested two posts ago. Is there anything preventing you from doing that?
Message 6 of 34
(14,563 Views)
I want to change column, to create a 2×2 array of strings after a colon is found on the string.
I want to change line and column after a colon is found in the string, in order to create a 2×2 array.
Thanks, and sorry for not making myself clear.
Message 7 of 34
(14,504 Views)
It just a column change after the colon and a line change after the end of the item being deacribed. For example: if its battery lercsntage, it should put the heading (battery prrcentage) on the first column and the actual percentage on the second column, and then change line, and so on.
Thanks.
Message 8 of 34
(14,493 Views)
Then you really should have taken Altenbach's advice by using the Spreadsheet String To Array.  I did some more messing around with the data to turn those tabs into spaces first.
Message 9 of 34
(14,480 Views)
I can print it just fine, but in the array, it doesn't show the complete info, just the headings.
How can I fix this?
Thanks.
Message 10 of 34
(14,462 Views)
