convert string to 1D or 2D string to write in Spreadsheet
No, that's not a solution!
If you remove linefeeds from a multiline string, it is no longer a multiline string. You said you wanted a multiline string in a single excel cell, right?
Please let us know if your requirements have changed.
Message 11 of 13
(562 Views)
I probably did not explain myself well enough.... The solution works for me, I simply need to convert the input multiline string into an excel cell which must be, as far as I know, a single-linle string. Well, the Search and Replace does the job properly.
Just for curiosity,  you meant that is possible to insert a multiline string into a single excel cell?
Greetings
Message 12 of 13
(560 Views)
Yes, it is possible in Excel. It is not possible in simple ASCII tables that use delimiters. As I said, your code has nothing to do with Excel.
Message 13 of 13
(556 Views)
