convert string to number
Hi everyone , I'm new to labview and I want to show a number ( temp. ) on a diagram. I receive data from COM port as string.. how to convert this to number in order to use it in diagram or for comparison reasons.. Could you help ??
this is my block diagram :
Message 1 of 35
(7,228 Views)
Hi Eric,
I hope this can help you. You can delete the number to boolean array part if you don't need it, of course.
Kevin
Message 2 of 35
(7,211 Views)
Accepted by topic author eric_s88
Fract/Exp String To Number Function
Jim
Message 3 of 35
(7,198 Views)
It really depends on what the format of the data from the serial port is.
Is it ASCII data?  Then just use the Fract/Exp String to Number (for floats) or Decimal String to Number (for integers).
Is is raw binary data?  Then we need to know a few more details on the format.  Little Endian?  Big Endian?  Convertion factor?
Message 4 of 35
(7,191 Views)
Your question and your image doesn't mateches..If you are reading inside while loop with no delay, you will never get any data i.e. after it receives it will be overwriten with next empty string.. Use  string to number conversion in string paltte
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 5 of 35
(7,182 Views)
Not true at all.  You won't get an empty string unless the VISA Read timeout passes without any new data coming in.  The timeout on the VISA is set for 10 seconds, so the loop will not iterate that fast.  It will only iterate as fast as it takes for 4 bytes to arrive.
Message 6 of 35
(7,162 Views)
What will happen after 10 sec if no data arrived?
--Ranjeet
Message 7 of 35
(7,158 Views)
Then you will get the string overwritten with an empty string.
But 10 seconds is a long time away, and it is a delay.
Message 8 of 35
(7,156 Views)
Its not delay if you are using inside while loop. Inside while loop if you see next read operation will start immediately after 10sec. This is little hazard. Little delay is always recommend. Delay between two consecutive VISA read.
--Ranjeet
Message 9 of 35
(7,150 Views)
It is NOT necessary to add an additional delay in this while loop.  The VISA Read will pace itself.  You will have 10 seconds between VISA reads if no data comes in.  You'll have some unknown amount of time between VISA reads if data is comiing in.  That delay will be a function of how frequently the other device is sending data.
Message 10 of 35
(7,144 Views)
