convert string to waveform
Hello 2 everyone.firstly i hav a problem bout how to build a waveform from the string using RS232 serial comm.I'm using instrument I/O assistant (IIOA) to communicate with message-based my hardware and graphically parse the response.The list of numbers below shown from ASCII from microcontroller. After I configure my hardware using IIOA, i can build  the string V n I easily.so my problem is i hav no idea how to convert this string into waveform.before that,i had using function string to byte array and then create a waveform graph.it is correct? n the last result i've got  the wrong graph bcoz the graph seen did not match from the string.here, i attach the files to anyone n i hope that you all can fix me the prob of this.thank u......Smiley Sad
V= 2, I = 4
V= 3, I = 5
V= 4, I = 6
V= 5, I = 7
V= 6, I = 8
V= 7, I = 9
V= 8, I = 10V= 6, I = 8
V= 7, I = 9
V= 8, I = 10
V= 9, I = 11
V= 10, I = 12
V= 2, I = 4
V= 3, I = 5
V= 4, I = 6
V= 5, I = 7
V= 6, I = 8
V= 7, I = 9
V= 8, I = 10
V= 9, I = 11
V= 10, I = 12
Message 1 of 9
(8,110 Views)
Refer to this thread. The delimiters to search for are different, but the problem is the same...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(8,100 Views)
Thank u very much...you're helped me a lot...but i almost forget 1 thing...actually...i didn't mean that value of V n I should be converted into XY graph...all i want to do is to make each V n I string convert into waveform graph versus time...that mean...I vs time & V vs time graphs.so i hope this prob will solve soon...I expected from u guys...thank uSmiley Happy
Message 3 of 9
(8,035 Views)
Message 4 of 9
(8,035 Views)
The code from the thread I referred you to is still mostly what you want - just plot each array separately instead of combining them into an XY plot.
Mike...
LabVIEW Champion
Message 5 of 9
(8,007 Views)
Hi Mr.Mike....
Thanks 4 ur advises and suggestions.Now...I'm be able to built the graph after I refer n learn the thread that u given......Sorry if i ask u so much...bcoz i'm newbie here in labview..so...i'm still learn until now...here i'm posting the example vi from my question above...i hope this example from my project can help the other members 4 the future references...thank u very much again mr.mike.
Message 6 of 9
(7,975 Views)
I am with same problem. Will anyone help this?
Cem
Message 7 of 9
(7,044 Views)
It may be 7 years later, but same problem -- same answer. Have you tried the solutions already presented?
When you have, post some code.
Mike..
LabVIEW Champion
Message 8 of 9
(7,028 Views)
Message 9 of 9
(7,021 Views)
