convert the range
i have attested a error -200524 which i et during operation
Message 11 of 20
(2,095 Views)
i have attested a error -200524 which i got during operation
Message 12 of 20
(2,095 Views)
changing sampling rate i found the this type of error  -200846
Message 13 of 20
(2,088 Views)
second error after changing samplin in daq assist
Message 14 of 20
(2,088 Views)
Remove the read function and check if the error still exists.or probe in error wire and check which function is introducing error
Message 15 of 20
(2,082 Views)
sill get error after removing read function and it is -20077
Message 16 of 20
(2,085 Views)
sill get error after removing read function and it is -200846
Message 17 of 20
(2,083 Views)
Hi hussey,
well, all those error numbers have a description. Right-click the error cluster to read it...
From your pictures we cannot see the configuration of that DAQ assistent, so it's up to you to debug your VI...
Message 18 of 20
(2,081 Views)
hi
i can't understend what to do with error can you eloberate. with privious kind of error daq only runs with sample on demand only without error but i want to perform with various sampling
Message 19 of 20
(2,075 Views)
Hi hussey,
so you use a USB6008/9 device. Those devices use software-timed AOs which will only handle upto 150S/s as can be read in the spec sheet. Did you notice that?
Message 20 of 20
(2,070 Views)
