convert unsigned to signed bytes
My oscilloscope sends a 2500 signed bytes in a string, and i want to plot these points. labview has a string to unsigned array converter, but i want to convert it to an array of signed integers.
is there an easy way to convert an unsigned array into a signed array (with 2500 elements)?
(5,126 Views)
You should be able to use the typecast function with a signed array as the type input.
(5,122 Views)
Hmmm... I can't figure out that type-casting thing. But just in case anyone else runs into this same problem (I can't be the first guy to take data from an oscilloscope), here's how I converted my unsigned bytes into signed (and scaled) floating poing voltages.
The conversion takes place in a for loop.
The scaling takes place in a formula node.
(this program may not be optimized for speed).
(5,099 Views)
(5,087 Views)
