convert version 6.1 to 6.0
Please can anyone help me, I have my program as a version 6.1 from using a trial version of Labview 7.0 now I can open it in version 6.0. Can any one please help me convert back to version 6.0.
Cheers
(2,719 Views)
When I opened it in 6.1, there was an error in the formula node. I didn't check what it was, but its possible this is due to syntax differences in the formula node between the versions.
___________________
Try to take over the world!
(2,715 Views)
thanks i can open it now.
(2,709 Views)
Hi Kelly
my name is Tonio, i'm working in your same University with the same engine.
I'm working with the two-coluor method with high speed camera.
I need to do the calibration of the high speed camera by tungsten ribbon lamp.
I have in my hands your PhD Thesis, i fond only the calibration table, there isn't write the method that you have used to do the calibration.
I took the movies in front of the lamp, now i have analized the frame by frame. The problem is that the camera gives frames in RGB colour. I put the frames in a intensity graph and i take from it the intensity values of the pixels. I saw that there is so much variation of the intensity in every frame.I think this is due to the intensifier in front of the camera.
I would like to know how you did the calibration, please.
I hope you will see this post and i hope that you will can help me.
Thank you so muche for yur help. Sorry for my english.
Tonio
(2,580 Views)
