converting a P.S.D trace to a time domain signal
Hi all
A project I am working on at the mo uses a 1MHz pulse train of 1% duty cycle to switch on and off a carrier of the order of 6GHz. I have been able to recover the sinc spectrum of this signal on a hp8562a spec an. The recovered P.S.D trace is made up of 601 data points. From this trace I was hoping (by the use of the inverse fft function) to recover the time domain pulse so as to measure its rise time, fall time, width etc. I was hoping someone had tackled a similar problem before.
Is what I am trying to do at all possible from a simple PSD trace?
If so should I use the real or complex inverse fft function?
Can I recover a time axis without any phase info?
I know I ask a lot but am under pressure for time and a
ny help would be much appreciated, no matter how small!
P.S I am working with LV 6.02, win XP and talking with spec an using GPIB.
T.I.A
Dec.
(2,819 Views)
It is (generally) not possible to re-construct the time signal from a Power Spectral Density measurement because, as you mention, you've lost the phase information. Both real and complex IFFT require complex input data (but return resp. real and complex output data).
(2,819 Views)
