converting boolean into number
How to convert a boolean button into the number that i wanted? For example, i have 3 boolean button,when the first button pressed, number 1 will show up, second button -> number 3, last button -> number 4 i have tried to use boolean array into number, but the number that show up was not like what i have expected any help??
(7,605 Views)
Hai mahe,
what u gave as the input for 'boolean array to number' ?
(7,588 Views)
Hi Mahe,
Please see the attached vi for getting the results as required by u.
Alifiya
(7,586 Views)
Obviously
  • first button --> 1
  • second button --> 3
  • third button --> 4
can't be resolved with a boolean array to number function !
Did you mean 1, 2, 4 ?
Could more than one button be pressed at a time ? If yes, what would the expected numbers be ?
Message Edité par JB le 04-24-2008 08:05 AM
(7,583 Views)
and here is much simpler one
(7,578 Views)
ya,, it is something like the button on the calculator.. when u pressed 1, it will show 1.. just like tat.. seems like the example given almost get the result of what i want.. thnks to both of you.. really appreciate it
(7,557 Views)
