converting characters to numbers
VISA Read reads the data in ASCII format and outputs them as characters. I however would like to have them in DBL formart. How do I convert?
(2,905 Views)
try using the scan from string.vi (Functions --> String)
good luck
Dan
(2,905 Views)
Thank you for contacting National Instruments.
You may also be interested in the Decimal String to Number function located on the All Functions >> String >> String/Number Conversion palette. Either solution will work fine.
Best Regards,
Matthew C
(2,905 Views)
thanks!
Have a great weekend!
Ivanka
(2,905 Views)
