converting data from a generic LabVIEW object to a string like the Object.ToString method in .NET
Is there a way to do that?
Specifically, I want to print my monitor configuration which LabVIEW returns as an array of clusters of numbers and clusters of numbers. I can manually write code to convert that data to a string but if there's an automatic way to convert that to a string, that would sure save some time.
(6,320 Views)
Accepted by topic author bruce008
Hi Bruce,
The Flatten to String function (available in the strings palette) should do what you've described. If you're looking for a more human-parsable string output I'd recommend the flatten to XML or JSON functions, found in the same location.
-Edit- If you're using LabVIEW 2012 or older, I don't believe you'll have access to the shipping flatten to JSON function, although if you prefer that format there is a community toolkit available here:
Interactive Internet Interface: JSON Toolkit for LabVIEW.
https://forums.ni.com/t5/JSON-Toolkit-for-LabVIEW/bd-p/8520
Tom L.
(6,310 Views)
@0utlaw wrote:
Hi Bruce,
I think you are misunderstanding. He doesn't want to flatten to a string necessarily, but give an object a string representation with some meaning. Unfortunately, a generic LabVIEW class does not have this method build in. You can, however, create a base class that all your objects inherit from which has a dynamic dispatchmethod called toString.
(6,303 Views)
I was looking for a human-readable string, but you did answer my question perfectly so I have to accept your answer and ask again! I'll wait awhile.
(6,297 Views)
@GregFreeman wrote:
@0utlaw wrote:
Hi Bruce,
Hello Greg,
You're right-  Bruce indicated he was looking to convert a cluster of numerics, which may or may not have been class data, so I was interpreting "object" to mean a more general GObject (well, maybe not specifically, but that encapsulates the cluster in this case) rather than a class.  Your suggestion for adding a base utility class containing generic methods like this is also spot-on.
Best Regards,
Tom L.
(6,273 Views)
