converting labview 7.0 to 6.1
I have a set of vi's from FTDI that are from labview 7 that i need converted to 6.1.  They are for using a usb dll.
Thanks Jeff
(2,726 Views)
Accepted by topic author jbreefer
(2,720 Views)
I have a similar problem. I have a LabVIEW driver compatible with 6.0, 6.1, 7.0, 8.0, 8.2 versions while I am using LabVIEW 2010. What can I do to use this driver.
thank you.
(2,710 Views)
LabVIEW 2010 can open VIs written in those versions just fine.
If you have further issues please create a new thread - do not hijack someone else's thread (which is not related to your issue).
(2,705 Views)
