converting problems with period decimal separator
I want to convert a spreadsheet string of floatin point decimals into an
array.
spreadsheet string uses period decimal separators, the array shall use
commas.
But by converting it using the Spreadsheet to Array.vi I lose the fractional
part, all decimals are rounded to integer.
Do I use the wrong format syntax (" %.3f"), or is there another trick?
thanks for help,
Daniel
(3,066 Views)
Hi Daniel,
I think you'll have to use "%.;" to set the decimal separator to ".".
See this question : http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000A1CE0000&USEARCHCONTEXT_CATEGORY_0=_49_%24_6_&USEARCHCONTEXT_CATEGORY_S=0&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_INCLUDE_0=decimal+separator&USEARCHCONTEXT_INCLUDE_S=0&UPostedFromTimeSearchArg_0=29&UPostedFromTimeSearchArg_1=10&UPostedFromTimeSearchArg_2=2003&UPostedFromTimeSearchArg_S=4&UPostedToTimeSearchArg_0=26&UPostedToTimeSearchArg_1=4&UPostedToTimeSearchArg_2=2004&UPostedToTimeSearchArg_S=4&USEARCHCONTEXT_TIER_0=2&USEARCHCONTEXT_TIER_S=0&USEARCHCONTEXT_QUESTION_0=decimal+separator&USEARCHCONTEXT_QUESTION_S=0
Hope this helps !
Julien
(3,066 Views)
You might try "%,;%.3f" or "%.;%.3f". I think the string has decimal "," and
"." is expected, or visa versa.
Wiebe.
"Daniel Ewert" wrote in message
news:c6j2hs$qc8$1@nets3.rz.RWTH-Aachen.DE...
> array.
> commas.
fractional
> thanks for help,
> Daniel
(3,066 Views)
