converting raw 9236 readings to strain readings
Hi All,
I have a system set up which records the inputs from 12 9236 modules through 2 cRIO chasis in FPGA mode.  I am now in a position where I want to analyse the data, at the moment I have got the data in front of me in it's raw format.  The trouble is I am not 100% sure what these numbers actually represent!!!!!!  Do they represent Voltage values or something else?
The module is configured to return calibrated results (ie calibration mode:  Calibrated)  I guess this is merely tells the unit whether the module has been calibrated or not?
I have attached an output for my strain gauges and accelerometers (They need converting as well!)
(2,540 Views)
I've attached the actual vi, and one of my many data files for you guys to play with.
(2,537 Views)
NOTE:
The data is not in an xls file, I just had to rename it so it would allow me to upload it!!!
Don't try adn open it in excel!
(2,533 Views)
