converting square wave to double
I am trying to pass to square wave signal into math script.  I am assumeing that i have to convert the signal into a double.  Is this possible?  If so how could I convert this signal so it can be passed into math script?
Leif
(2,504 Views)
Which data type does your square wave signal has? If it is a waveform you can get the value as an array of double with the Get Waveform Components primitve.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,502 Views)
