converting time stamp to double
I am currently using the write to spreadsheet file.vi to save data.
It looks something like this:
18893i4FE97741C14A2B8F
I also want to add the date and time stamp into the saved data but do not know a way of converting a date and time stamp to 'double format'. When the date and time stamp is in teh double format I can easily concatenate the data stream with the 'date and time' in a 2-D array.
Nevica
Message 1 of 11
(28,421 Views)
Look on the math palette.
18899iAF35943D3543F3E1
Tim
GHSP
Message 2 of 11
(28,417 Views)
What I would like to do is convert a date and time stamp (which has the form something like this: xxxx/xx/xx  xx:xx:xx) to a 'double'. The problem I am having is the non-numeric characters.
Message 3 of 11
(28,402 Views)
Like this
Tim
GHSP
Message 4 of 11
(28,393 Views)
Thanks for your example. BUT in your example your are converting a number to a double precision float. I want to convert a string to a double. The problem I am having is the formatting of the date and time stamp which includes '/' (forward slashes) and ':' (colons).
Any ideas anyone?
Nevica
Message 5 of 11
(28,380 Views)
Message 6 of 11
(28,375 Views)
Could you not use "Get Date/Time in Seconds"?
Jim
Jim
LV 2020
Message 7 of 11
(28,372 Views)
Any ideas anyone?
Nevica
You asked how to convert a timestamp - not a string.
You can use the Scan From String.
Message 8 of 11
(28,356 Views)
My apologies for not being clear.
It looks like get date and time in seconds will work as you have both suggested.
Nevica
Message 9 of 11
(28,348 Views)
aeastet - nice icon
Jim
LV 2020
Message 10 of 11
(28,333 Views)
