converting to real and imaginary from amplitude and frequency
basically there is a control of the amplitude and frequncy, so as to changes with resoect of real and imaginary
(3,329 Views)
Do you have a question?  Your sentence doesn't make any sense.  Please provide more detail of what you are trying to do.Smiley Wink
(3,328 Views)
Hai sean1985,
I think you want to convert amplitude and frequency into real and imaginary values.
You can find it in programming--> Numeric--> Complex
Hope this helps....
Mathan
(3,311 Views)
See the attachment, if this is what you require.
I ve enabled the Unit Label for the Freq control on the FP. Just rt-click & select to enable the Unit Label feature to dorectly key in the Deg [angle] value for the frequency parameter. Normally it takes frequency [or phase angle] in radians in LV.
- Partha ( CLD until Oct 2027 🙂 )
(3,300 Views)
Thanks guys.... I got it.. By how come u know about the VI, where can i learn more abt such VI existence?
(3,296 Views)
First of all go through all the functions and controls available.
Just right click anywhere on the block diagram and navigate to know about functions
Just right click anywhere on the front panel and navigate to know about controls
Mathan
(3,293 Views)
The original poster and others keep talking about amplitude and frequency.  But the function calls for amplitude and phase  (theta)!  It calls for an angle.
Message Edited by Ravens Fan on 05-08-2008 09:40 AM
(3,271 Views)
