converting video formats
I need to convert an AVI file I have created in LabVIEW into somthing more compact. It looks as if I convert it into a MP4 file using a H264-MPEG-4 AVC codec or similar, I can compress the AVI file down to 3-4 % of original size in AVI.
I don't think there are any LabVIEW tools available for the job, but if I could locate an external executable that take some input parameters , so I could run it with the System Exec.vi.
Anybody, anything ?.......
Martin
(9,376 Views)
Hi MartinP
As far as I know there is no way of saving as an MP4 directly from LabVIEW, but I like the idea of using System Exec.vi.
FFmpeg might do the trick: it takes command line arguments such as:
ffmpeg -i input.avi -q:v 1 output.mp4
You could even string together a bunch of these commands into a batch file and execute that.
[Disclaimer: NI are not responsible for the content of the external link.]
Let me know if this is what you are looking for!
Leah
(9,337 Views)
Leah
Yes, it is something like this I'm looking for. Right now I'm working on testing it out using the libav system (avconv.exe), a solution found under https://libav.org/about/ .
If I get into problems with this one, I'll go back and test FFmpeg, as you suggest.
Thanks for your input.
Martin
(9,331 Views)
I've also used the command line tools of VLC to convert media files.  In the past I could extract the audio from any video that VLC can play (no need to know the codec) and into any audio format.  I assume the video converting tools have similar command line functions.
(9,321 Views)
Accepted by topic author MartinP
I can add that the conversion worked very good.
Example; starting with a original BIN file at 15 110 621 KB.
The resulting AVI file was 329 597 KB after converting with the LabVIEW tools..
Then I used the libav system run from SystemExec, and
converted  the AVI file into an MP4 format. This ended up as filesize 14 962 KB. This means a total reduction down to 0.1% of the original, from BIN to MP4. That was a very good result to me.
Martin
(9,295 Views)
can you please show me the step to doing that? i tried but didnt work correctly.
Day@
Certified LabVIEW Associate Developer
(8,747 Views)
