convertion of the string
I'm new user of Labview.
The attached picture shown the string that i get from the PIC. So how can i convert the input string to the expected format?Between, it is any problem of
the write to measurement file?
Thanks.
(2,518 Views)
The read string:
AN000293
AN is a initial character and  00 means sensor number (in case i need to use 12 temp sensors) and the final four digit is the value of the temperature (degree celsius).
Need help!!!
(2,504 Views)
Have a look at the string subset block.
(2,489 Views)
use scan from string with format AN%2d%4d => this will split the string up in 2 parts => sensor and value.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(2,475 Views)
