coordinate change picture
Hello friends.
I have a problem with picture coordinate.
Can I change the origin from top and left to down and right.
(2,518 Views)
hello,
I believe that there's no direct way of doing that.
But you can explain me better your problem, and maybe I can discover solution for you.
You know that you've the object property that return the bounds? And with this and simple math, convert coordinates.
But the best thing it's if do a simple example and tell the Labview version that you use.
Software developer
www.mcm-electronics.com
PORTUGAL
(2,496 Views)
