coordinate measurement (using NI 1776C smart camera)
I am using NI smart camera 1776C to track (to find coordinate of a point marked in plain paper) a point. Then the paper is shifted(by some means) from its original position and i have to measure the distance(displacement) between this two points(the marked point before and after the change in position of the paper).
Also i have to acquire the continuos online data(pixels or mm) so that it is possible to control (PID controller) the position of the marked point.
I am using Labview plattform.
Is it possible to acquire data from the camera using NI 9219/NI 9223.
I kindly request you to give some idea how to proceed.
(2,669 Views)
The the analog input module cannot be used by the smart camera all by itself.  You need to integrate a solution that includes the analog module in a cDAQ, or cRIO backplane, if you need vision and positional inputs simultaneously.
Encoders or potentiometers (less common) are used for this purpose if you have a linear stage, or other motion actuator.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(2,638 Views)
