copy and transfer a text file
hi need help how can i get the text file and transfer it to diff directory..
on the transferring time the progress bar should appears...
how to do tht?
Message 1 of 19
(4,045 Views)
Hi jeyanthi,
you can write your own function to copy the file. Open both files and copy one file to the other. Use the binary functions for it. In you while loop you can then insert a slider which shows the current position.
Mike
Message Edited by MikeS81 on 05-27-2008 10:22 AM
Message 2 of 19
(4,039 Views)
hi jeyanthi
                 you can use the move icon for that. you will find that in files----> advanced file ios------> copy, move ...............
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
Message 3 of 19
(4,037 Views)
hi
thks but this error occurs
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.
NI-488:  Non-existent board.
if i choose to open the current folder for example i open C:\
why it occurs and how to avoid it?
plz
and the slider how to do in while loop can i get example
Message 4 of 19
(4,033 Views)
Hi jeyanthi,
when did this error occur? Did you try to copy the file step by step?
Do you want to copy one file or all files from a folder?
Here is an example with a for loop.
Mike
Message 5 of 19
(4,029 Views)
let say i have a text file in E:\  read.txt i want to copy it to c:\ how to do tht..erm
i use copy option frm advance file >> copy
Message 6 of 19
(4,027 Views)
Hi jeyanthi,
i think you can only show a slider with relative correct position if you copy the file byte by byte. See the attached example.
Hope it helps.
Mike
Message 7 of 19
(4,020 Views)
i can copy the text file let say c:\read.txt to e:\read.txt.
but i dont want the user to write the the name again
the user only can choose the directory only and save the (read.txt)
how  to do tht?
Message 8 of 19
(4,019 Views)
Hi jeyanthi,
Mike
Message Edited by MikeS81 on 05-27-2008 11:03 AM
Message 9 of 19
(4,016 Views)
thk u
Mike its works
thk u again Smiley Wink
Message 10 of 19
(4,007 Views)
