copy bmp file from memory card through ethernet connection
I have one computer connected to Keyence vision system through ethernet.
After vision inspections, images will be moved from buffer to memory card in Keyence controller.
Any idea i can retrieve those image files from the memory card to my computer?
(2,324 Views)
You would need to look at the Keyence vision system API to see if such an operation is possible.
(2,309 Views)
