copy build script
Is there a way to copy a build script from one project and paste to another project?
George Zou
(3,726 Views)
Hi zou,
you can copy the part of the build specification from the project file and insert it into the other project file. A project file is an XML file.
Hope it helps.
Mike
(3,705 Views)
Not in LabVIEW 8.5.1.
Is the project file pure XML file?  Does it contain anything not XML?
George
George Zou
(3,687 Views)
I used Microsoft XML Notepad to copy the build script to the other project.  But LabVIEW doesn't recognize added script, as if it's not there.
George Zou
(3,678 Views)
