copy data into array constant
Hi, I saw in a example that someone store the data of a spectrum into an array constant, see the attached please.
I am trying to do the same, and copy a colum data into the same constant, and found it is not easy as I thought?
Can anyone please help me out?
(4,034 Views)
Accepted by topic author sxy248
Output the array to an indicator, r-click the array and change to constant.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,023 Views)
It works. Thank you.
(4,001 Views)
Please mark the solution. 😉
/Y
Qestit Systems
(3,982 Views)
