copy folder through ftp
Hello all,
For my application I have to copy a folder containing some configuration ini files. The folder is located on a RT PXI and the computer that send the "request" and receives the folder is a WinPXI.
1, is ftp the best way to copy files from a RT PXi to a WinPXI ?
2, if it is, what is/are the ftp command(s) to do that ?
Thank in advance for any help.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,631 Views)
Maybe the RETR command could do the job, no ?
Epictetus
Antoine Chalons
(4,625 Views)
hi there
you can use DataSocket functions for ftp-ing. see attachment.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,617 Views)
Thank you for this Chris, but what I'm trying to find is  a function that copies, not just a file (I know how to do this), but a folder with many sub-folders and file inside.
If it exist, that's perfect. If it does not, then I'll have to develop it myself by getting the "tree" of my main folder and copying every last folder and file to the target direction.
Epictetus
Antoine Chalons
(4,611 Views)
hi there
hm, just a suggestion: whenever your RT-App creates a new file on your PXI you could write the list of files in your RT-folder in a file named "list.txt". then you get this file with ftp to your PC and fetch all files listed in list.txt inside a for loop using datasocket (i'm using datasocket - functions instead of ftp-system calls because they return error codes).
best regards
chris
Best regards
chris
(4,607 Views)
Thank alot for the idea !
I'll do something like this. 😉
Epictetus
Antoine Chalons
(4,602 Views)
