copy property node in another frame
Here is a better way to do it.  I saved this in Labview 8.0.
- tbob
Inventor of the WORM Global
Message 11 of 13
(580 Views)
Hi Dana,
here's a somewhat cleaned up version of your vi...
Rule of thumb:
Whenever you have the static code in loops (or in each case of a case structure) put the code outside of the structure - as I have done for your 12-case-structure...
Next step: replace the case structure with an array containing 12 strings and use an index array function to get the correct string...
Message 12 of 13
(576 Views)
GerdW, tbob, I appreciate very much your efforts. Thank you truly!
They work nicely now.
Dana
Message 13 of 13
(570 Views)
