copying application
Hey!
I want my appication .exe to be run on one PC only.Is there a way to protect multiple copies ,like some ini file command or sumthing??
Cheers
(3,536 Views)
Hi DeWalker,
one solution is to use a hardware id. Check if the correct id is present in your system and start your application in the true case. Another solution is to use a dongle.
Hope it helps.
Mike
(3,526 Views)
You mean i should geta  system id thru some LV block and verify it.......What sort of blocks are available for hardware id check??
(3,522 Views)
Hi DeWalker,
maybe the volume id which you get with a "dir" cmd in the command window is enough for you. You can get it into labview with the system exec function.
Mike
(3,516 Views)
I second the idea of using the volume ID. Bear in mind however, that in the (unlikely) event of the PC needing a replacement drive for whatever reason, you need to be able to edit the software lock. Even if it is to edit and recompile your code
_____________________________
- Cheers, Ed
(3,489 Views)
