core 1 and core 2 exercice v 8.5
hi , can help and joint me attachement of core 1 and core 2 exercice v 8.5
(3,303 Views)
Are you asking if anyone saved the exercise files from ten years ago and can attach them to the forum?
I'm going to bet that in the rare event someone still has those, they'd be too large for the forums to host.
Do you have the manual?  If so, you should be able to put most of the examples together without having the VIs.
(3,289 Views)
i have the vis but problem that's not the same version of 8.5
(3,287 Views)
there is a forum for version conversion. You can ask conversion there.
(3,263 Views)
If you're using a version of the core classes that has newer VIs, keep in mind the course likely will have things that aren't consistent with 8.5.  Expect to run into that as you go through the course
(3,238 Views)
