correct connection in max but error in labview
i'm trying to connect tegam 1830a power meter to labview using usb-serial port
the device act correctly in max, but in labview the read visa function gives timeout error
i send order *iDN? to the device , and its work in max but not in labview VISA ERROR.png
(3,286 Views)
You aren't appending a termination character. Right click on the string constant and select '\' Codes Display. Then append a \r or \n, whatever you have in MAX.
(3,276 Views)
Forgive me for saying this, but when you open VISA with MAX, you are much slower in asking for the VISA "Write" than when you wire the two functions sequentially in LabVIEW.  Try putting a delay of, say, 200 msec between the VISA Open and the first Write.  Similarly, put a delay between the Write and the Read.
I presume that you did exactly these steps in MAX, correct?  What about terminating the Write command -- did you have to give MAX a <CR><LF>?  (I don't see it in your VISA Write).
Bob Schor
(3,265 Views)
That wait is not needed since it looks like the Termination Character is being used.
(3,255 Views)
