correlation
Hi Wirers,
I have collected data with severalo parameters which are obviously
related to each other. But just as obviously there is a latency
between my different parameters, meaning that due to measurement
techniques there will be some time between the occurence of a
change in data A and the change of data B. If I check for correlation
between the two it will be weaker than it actually is.
Does Labview eventually offer a possibility to search for a cor-
relation in data variables with a latency ("search for maximum
correlation")?
If not, how could I do that?
LV version is 4.01, OS is Win98.
Thank You,
Christoph
Message 1 of 1
(2,680 Views)
