corrupt block diagram
Hi all,
I have a VI which is able to open and I can even start the front panel, but when trying to open the block diagram, the screens stays white and Labview crashes.
Is anybody able to open the block diagram of this file?
Thank you in advance>
Greetz, Bart
Message 1 of 9
(3,838 Views)
Tested with LabVIEW2013 and LabVIEW 2014 f2 (Without loading DAQmx Vi), it's OK.
Reg
Message 2 of 9
(3,832 Views)
No problem with LV2014f1 either - just an annoying "execute on load" setting...
Hint: use typedef'd enums for your statemachine!
Message 3 of 9
(3,824 Views)
Works here on 2013 as well. Try a recompile of your code. That might fix it.
PaulG.
Retired
Message 4 of 9
(3,793 Views)
To force a recompile, hold down the shift and control keys and click the run button.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 9
(3,769 Views)
Thank you all for the quick replies.
I'll try the suggested recompile option. If the problem still persist, maybe I should consider reinstalling Labview.
Message 6 of 9
(3,732 Views)
For you whom it worked, did you get a recompile star? Maybe you can repost the working one?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 9
(3,720 Views)
Saved for LV2012
Message 8 of 9
(3,716 Views)
A foreign colleague of me also tried to open the file and managed to do so, with the exact same version of Labview, so I think something was wrong was the Labview.
By doing a repair session in the Labview Installation I managed to get the file working again.
So the error wasn't in the file itself, but in Labview (I assume).
Thank you very much all for helping me find a solution.
Message 9 of 9
(3,678 Views)
