corrupted serial data when reading
Hello Friends
Im working on a project that read a string through the serial port from a flow meter.
the string that the flow meter sends has this pattern. its a comma separated string:
0021,00029504,00032622,0115,0,0,00000000,00000006,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:48,12/04/12,2110,00000000,0
i already proccesed the data with this VI (please fell free to give me any suggestions Smiley Happy ). Please see 1.jpg
I am having the following issue. when receving data from serial, several strings show up corrupted. please see good.jpg and bad.jpg. i have tried to read the serial data on hyperterminal, and all strings show up ok.
i will appreciate any suggestions and advises on how to fix this!
thanks in advance
Message 1 of 17
(5,698 Views)
Don't have the VISA Initialize Serial Port inside the loop. It is also not a good idea to use the VISA Bytes at Serial Port when you configure the serial port to use a termination character on the read. The wait served no purpose. Just request some large byte count.
Message 2 of 17
(5,691 Views)
Double check your parity and stop bit settings.
Message 3 of 17
(5,689 Views)
Hi moreins1,
                                 Friend this is serial communication. you can't parallely read & close the VISA. If the number of byte to be read from serial communication is fixed than close the VISA after each read operation & repeat the while loop in 1 or 2 sec delay. In while loop open read & later close. this will work perfectly.
Thats why your data is corrupted.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 4 of 17
(5,675 Views)
As others have said, initialize your serial port once before your main loop.  You should then close the port once the main loop is complete (which you are already doing).
When I've seen this kind of corruption, it is usually a bad baud rate.  Reinitializing your port each loop could be causing that issue.
It doesn't look like you really have a termination character, so turn that off (part of the serial port setup VI).
Message 5 of 17
(5,663 Views)
Ranjeet,
You must be looking at a different VI since the posted one does not read and close in parallel. The wait you mention is not based on any knowledge of the serial device and is probably not required if the device sends a termination chaeacter. And, do NOT open and close inside the loop.
Message 6 of 17
(5,661 Views)
hello people.
thanks a lot for all your suggestions. im working right now on this.
will let you know anything
rgds
Message 7 of 17
(5,631 Views)
hello
actually, i have one more question.
this is the data viewer i have on my vi. it shows each data string that my serial device is sending. this string will change 10 times in a second. this is OK. right now, its showing 1 string at a time:
0021,00029504,00030816,0110,0,0,00000000,00000009,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:54,12/04/12,2173,00000000,0
what i want now is to actually append all this data in the viewer so i can copy and pasted it to notepad. i would like it to show like this:
0021,00029504,00031123,0107,0,0,00000000,00000009,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:54,12/04/12,2174,00000000,0
0021,00029504,00030948,0104,0,0,00000000,00000009,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:54,12/04/12,2175,00000000,0
0021,00029504,00030866,0103,0,0,00000000,00000009,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:55,12/04/12,2176,00000000,0
0021,00029504,00030903,0105,0,0,00000000,00000009,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:55,12/04/12,2177,00000000,0
0021,00029504,00030888,0105,0,0,00000000,00000009,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:55,12/04/12,2178,00000000,0
0021,00029504,00030836,0104,0,0,00000000,00000009,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:55,12/04/12,2179,00000000,0
0021,00029504,00030545,0095,0,0,00000000,00000009,0000,00000000,00000000,0000,0,0,00000000,00000000,18:14:55,12/04/12,2180,00000000,0
and so on.........
Can you please advise on how to do this without actually monkeying around with the VISA inicialize?
thanks!
Message 8 of 17
(5,630 Views)
@moreins1 wrote:
hello
and so on.........
thanks!
You're gonna have to put that string into a shift register to bring it back around.  Then you'll have to concatenate it with the current string (add a return so they end up on different lines) and take the output to your indicator.  Be careful what you wish for... if it's updating 10 times a second, it will eat up memory like crazy.
[edit]
Didn't realize you wanted to cut n paste to notepad... why not just take the original output to a file instead of an indicator?  Cross beat me to it.
Bill
CLD
(Mid-Level minion.)
Message 9 of 17
(5,619 Views)
You could just create a file and write a new line to it each time you get a new message or a button press.  Close the file when the program exits.
Message 10 of 17
(5,605 Views)
