could not use the math interface toolkit
I have labview 8.0....and i am unable to use the math interface kit it provided....please help..
(3,155 Views)
swap,
Could you provide some more information about what is not working with the Math Interface Toolkit?  Are you seeing a problem during installation, or is it when you attempt to create .mex files?  Any details you can give would be extremely helpful.
Chris M
(3,153 Views)
I have labview 8.0....and along with math interface toolkit 1.0 has been provided....which i think is not compatible with 8.x versions ....i anyway installed the toolkit and it is giving an error messege
(3,150 Views)
swap,
You are correct that the Math Interface Tookit 1.0 is not compatable with LabVIEW 8.0, which probably exlains why you are seeing an error.  You may have already seen this knowledgebase.  As suggested in the knowledgebase, you can get version 1.0.2 by visiting the Upgrade Advisor.  You can also contact your local NI sales representative.
Chris M
(3,139 Views)
