06-09-2005 03:48 AM
06-09-2005 02:47 PM
@shenzhengpib wrote:
thanks
06-09-2005 08:44 PM
06-10-2005 01:52 AM
06-10-2005 02:00 AM
dear rolfk:
i think communication by parallel port is enough to me. any detailed info ?Of course if usb is ok, i prefer it. by the way, i cannot download the circuit diagram of you mean in
"If you are into building your own hardware you could also checkout http://www.elektor-electronics.co.uk/Default.aspx?tabid=28&year=2004&month=12&art=51933&PN=On&SearchText="
06-10-2005 02:33 AM
@Albert Geven wrote:
Hi Rolf
I don't agree that the parallel port is slow and especially not unreliable.
On a modern pc you get better than 10kHz on I2C (normally 100kHZ) and because it is a a handshaked bus
it is not unreliable, even not under windows.
O the usb chips we use and have seen from other firms you get faster communication but not much faster,
and the latency is even bigger.
The future for I2C is in the USB bus, I agree. We are working on a solution that supports this.
But it will take a few moths to get all software and hardware glued together.
06-10-2005 04:03 AM
