count occurences
I want to save a occurence of a bit.
For example:
A Bit is switch from 0 to 1 increment a from 0 to 1 and write 1 to a file
if the bit turns back to 0 and comes up to 1 again, add 1 to value within the file. The result should be 2 and so on.
The reason is I want to genertate automatically Key names within a configuration file, dependent on the Bit event.
e.g.
[MyMeas]
Mea_0 = 1;2,5;40;35;23....
Mea_1 =
Mea_3 =
[SumMeas]
Sum =
Can anybody help me?
Thomas
Thomas
(2,786 Views)
Try this, don't forget to create a file (in my case in c:\temp\count.txt) before running.
Hope it helps,
Paulo
(2,778 Views)
Yes! You did it!
Thank you very much
Thomas
Thomas
(2,773 Views)
